Electric clutch wires broken
Bigmo
I have 2004
Husqvarna GTH2548. Does anyone know if there is a plug in on the clutch end of the wires to the clutch? There is one on opposite en but I can't see what I'm doing! The wires rubbed on a fraying drive belt and broke. I tore off the seat and gas tank but the clutch assembly is stuck way up there n there.
If there is wires coming off of the clutch that plugs into the mower wiring harness a short distance from the clutch, then there is no plug on the clutch itself.
Bigmo
Thanks! This is a total knuckle buster to get at!
Google "taryl fixes all- clutch repairs"
The whole shooting match is laid out in the video.
You are not going to get the wiring done with the clutch in situ.
