- Nov 29, 2014
- 24,995
So the "kit' was actually a replacement carb with some gaskets & fuel lines, not a rebuild kit ?
Without the testing tools we are really shooting in the dark.
However a red neon spark tester is a piece of kit that you will get good service out of, so order one of them, install it on the engine then start & run the engine till it stops, munted in a vice so you can watch it.
If the red flashes ( well orange actually ) suddenly stop then the engine cuts out or if they break up and the engine stops then there is an electrical problem.
If OTOH it continues to spark while the engine is slowing down you have a fuel problem.
My money is still on a pressure leak, but I can be just as wrong as the next man.
While you are spark testing, loosen off the muffler, you can take it off if you like but they are amazingly noisy little buggers without their mufflers.
IF it runs fine with the muffler loose/off then you have a blockage in the exhaust which is suffocating the engine.
Usually a blocked muffler will allow the engine to idle all day & night but die the instant the throttle is touched.
There is a better than average chance the new carb you bought needs to be set up, instructions are on the web manual .
The rotary valve carbs are a mix of a butterfly carb & a slide carb.
THe rotary valve opens up more air , just like the butterfly does .
Under the rotor is a tapered needle as the rotor turns, it also rises pulling the needle out of the jet & allowing more fuel to enter the engine.
They are very robust, much better than the butterfly carbs but a bit fiddly to set the idle properly.
