stushug
I put a brand new spark plug in, and after attempting to start, I pulled it and it was wet, so I'm pretty sure fuel is getting into the cylinder. I'll change the fuel tomorrow and see if anything changes. I'm also going to check for proper compression. What readings should I get with this engine?Did you see the fuel go into the carb, or just see it going through the fuel lines? Let us know what happens with fresh fuel.
