seagiant
 - Aug 3, 2013
- Threads
 - 33
 - 181
Hi,
Bought a "does not run" PE-225 edger for $5 and slapped a cheap Chi-Com carb on it and it ran for about a couple of month and then would not start again.
Did the usual troubleshooting and found when I added a little mix to the cylinder it would pop off.
I also think it might of had a seal or gasket leak, so I said to hec with it and tore the whole engine apart and replaced oil seals and all the gaskets. broke the ring trying to clean it so also got a new ring and a new used cylinder because the spark plug threads were junk.
Then ordered a new OEM ZAMA carb and put it all together.
The engine would run but only on "choke".
Replaced the fuel filter and gas lines and finally got it to work on "run".
The high and low jets are accessible with a small flat blade screw driver and started to tune it.
The problem now is that the idle screw is backed all the way off and I have to keep the low needle out enough to keep the saw running, but the blade does not stop, like the low is having to run higher than what it should, but if I bring it down to where the blade stops and increase the idle as it should work, the edger cuts off???
Hope I'm explaining this right, the edger runs and I can use it but was hoping to get it tuned better than this???
Wondering if anyone has any ideas, should just about be a new Edger after all the work and the new parts?
