Echo edger: What I think so far
I used the edger a little bit around the house today and it was good. It was way to muddy (since the snow is melting now), so it got clogged quite a bit. But it is very simple to clean it out, just get a screwdriver and dig the dirt out. But I think it will be fine when everything dries. I probably will never be edging a customers yard when everything is this wet, so it was a good test. I also noticed that you have to push the throttle in farther to get the blade spinning than you do with a weedwacker to get the head spinning, I will probably be having it on full-throttle more often than I would with my weedwacker. But overall, I like the edger so far. I will put the light on the snowblower this evening, and take some pics.
