Looks really nice. :thumbsup: Let us know how it works out. I'm thinking of getting one, since I really hate dealing with the electrical cord on my B&D Edge Hog. Can you adjust the position of the switch/throttle assembly on the shaft ? The only complaint I've heard is that it's a bit underpowered. My other possibility is the Stihl FC 56 C-E, which has a larger displacement engine.
I don't think there is much of away of adjusting the switch/throttle assembly on any of the units, they don't give you enough cable to do to much. The PE-225 is a 21.2cc engine and to notice any appreciable power difference with the Echo brand you'll have to spend $400 plus and get the PE-280 with the 28cc engine.
That's what I was thinking. The Stihl definitely has no adjustability to the switch/throttle, so that might have been a plus when considering the Echo. The Stihl FC 56 C-E costs only $20 more with a larger 27.2 cc engine that is rated at 1,1 bhp. Or, I could buy the pro grade FC 70 for $70 more with the same size engine rated at 1.2 bhp. Echo does not rate the power in their engines, but I have to believe that it would be less than the Stihl with 6cc more displacement.
