Ok, Try checking the spark arresting screen on the muffler first before you spend money on filters and lines, it not going to cost you anything. Use the process of elimination, cheapest things first. Your arrestor could be a flat screen on the side of the muffler or a round tubular screen through the side that you can just pull with a pair of pliers. Clean it with a wire brush and a air compressor if available. A plugged spark arresting screen will make the machine do exactly what you're describing.
