seagiant
- Aug 3, 2013
- 32
- 178
Hi,
Gifted this Blower, really dirty, cleaned it bought a new Carb...
Replaced Fuel lines,Sparkplug, and tried to crank and nothing...
Checked Muffler, checked spark, checked compression (120 PSI) pulled Flywheel, key is good, Coil was rusted...
Tested Coil with Vom and numbers run up and down and then settle out.
Wondering if Coil gives a spark on test but not good under compression???
Ordered new coil, only thing I can think it could be?
