MowerMike
- Sep 5, 2012
- 85
- 964
just out of curiosity do you know of any way to load test the battery? Just thinking to cover my bases... Thanks!
Well, its just a plain old lead acid battery, so you should be able to use a battery tester connected directly to the battery terminals. If you open the battery case, you'll just find two 12 volt batteries wired in series.
