Have used one in a homelite trimmer that made a noticeable difference. Basically I can trim the majority of my yard without using the throttle(homelite's are direct drive,no clutch). I am going to throw one in my M-Series 5hp two stroke as I have fouled the champion plug. Will see if I notice any difference, right now the M-series is not running very well, I am pretty sure that is due to the plug. Basically I was concerned that the injection might have a air bubble after I removed the line and turned the motor trying to figure out why there was no spark. So I added oil to tank so it was getting more than enough oil.
