Duratrac PTO Idler
Working on a Troybult/ Bolens 18/48 Duratrac mower.
This was bought new in Australia in 2001
Serial No 13074-0100768
The PTO tensioning lever, & pulley are RS.
Now the mower is fitted with an aluminium double pulley but the parts books all show 2 single pulleys.
Does any one know if it was a direct replacement upgrade or will the two single pulleys fit where the single one was before.
The other question is Partstree show a pair of steel pulleys but Jacks list them as standard plastic idlers.
All the other bits I need, the idler arm, shouldered bolt and sleeve bushes are listed NLA is there a specialist over there dealing with these mowers ?
Thanks,
Already been there.
They list both a plastic & steel pulley for this model in tandem but none of the other parts.
The Duratrac is a nice piece of kit alright.
Really a micro tractor and cast iron tranny, built to last no wonder they went belly up.
Send an email off to Sams as well which looked a bit better.
Just thought some one might know of a specalist Bolens dealer with a lot of obsolete stock.
All the usual suspect have little other then belts.
