(MMM) Montana Mower Man
Thank you.Worn V-idlers will cause slippage as the belt bottom out and then mower think got a longer than spec belt. Spec belt is 1/2 x 90 but when both v-idlers it appears to mower as a over 91" at 7/16" wide belt.
Check these pulleys for heavy wear.
