Drive Belt question
Forest#2
If you still have the old belt take a string or tape measure and measure the belt OD and compare it too the new belt and also compare the width.
Your new belt is probably little too long. A hint that it's slightly too long or wrong is the shuttle clutch has to be push down further to get a go.
I use a upholstery cloth tape measure from wal mart at about $4 and now days I ALWAYS measure the length of a new belt BEFORE INSTALLING BECAUSE like you I just throwed them on because they are SUPPOSE TO BE the right size. Not fun labor and cost wise when a new belt is installed and it's then used and the wrong size. I see several belts on ebay with same MTD part number and they are LISTED AS different sizes in length and/or width. The sellers don't even know why when asked about such. Randys small engine parts on ebay is one example of several same part numbers and different sizes and when asked they don't reply nicely.
I've found some new belt to not be as labeled and I always measure the old belt that being removed. Sometimes the old belt was on purpose re-sized due to issues such as yours by a previous guy working on the machine.
Usually they are little bit too long if the pulley are correct size and Ok.
If you install a too short belt on your shuttle clutch tractor you won't have a Neutral. Also the the clutching swivel double pulley spring has to be strong and connected to the proper place for good tension.
Belt specs depends on where you look. Sears has it at 1/2 x 101-1/6 Stens has it at 1/2 x 100.25. I can go out to shop in the morning measure the OEM 592855001 belt as I got two them on the shelf.
dawgn86
Thanks Star. I just ordered that belt today from Sears
dawgn86
So I wanted to update this one again..the drive belt was purchased on Amazon, not Lowes.
I kept having issues with it coming off, usually after stopping and shifting to reverse and then back forward. I ordered the belt from Sears parts and installed this weekend. It was maybe 1/4 inch shorter than the one from Amazon. The one thing I did find was one of the idler pulley nuts was almost at the bottom of the bolt that holds it on. I had to grip it with vice grips and use a thin wrench to tighten it back up at least a 1/2 inch.
So I have cut grass with it twice now and the belt has stayed on...hoping this solved my problem!
Forest#2
Also, You really have to keep a heads up on idler pulley alignment on that type motion drive. Sometimes just removing a idler to check the bearing or to replace a un-noticed spacer on top of the idler will fall off and not be noticed for re-installing/re-assembly.
dawgn86
Good point Forest
thinking my father in law tried to remove it at some point and didnt finish. It does have the carriage bolt head up above that is hard to access.
Forest#2
Your other belt will probably work ok now that you fixed the idler.
dawgn86
It probably would..got it put up for a spare
