- Nov 29, 2014
- Threads
- 64
- 24,759
I find the only problem with a test light is most will light at 8 volts , some even less, at least a DMM will read the true voltage of the battery ...... knowing I have a GOOD battery saves a lot of headaches. If I have suspected wiring or switch promblems I " jumper " right from the battery to the starter , of course thats AFTER checking oil, fuel and spark plug for spark . My DMM has a continuity beeper ( very handy ) and has been really helpful in many cases especially when checking a wire end to end ( can't do that with a test light unless you have voltage present ) . But I'm not here to "try" anybodys knowledge or skills ......... I simply want to help others ..... AND ESPECIALLY ..... the MEMBERS OF THIS SITE , who are trying to help all those that are seeking answers.
The tutorial in my original post covers the basic operation of a DMM , BUT then it does start getting into the "SCARY " part for most novices Actually .... voltage & continuity are about all I use that meter for , come to think of it !! Anyway ...... GENTLE - men ..... ya'll have a FANTASTIC day ...... Boobala .......:2cents:
By the way folks , check the prices on those DMM's in my original post , so ya do without a few beers , better to have the tool and not need it , than sit there wishing you DID have it , it's NOT a bank breaker and most people can get one easily .
yeah,
Some times you do need to know the vactual voltages but for at least 75% of the enquires we get here a yes/no is more appropriate as the owner is oft not mechanically literate which is why they are here in the first place.
