The key to securing a RoboMo would be to toughen it up a bit. Add a chainsaw feature -- plus a machete or two.:thumbsup:
I like your thinking.:wink:.. :smile:KennyV
While my DIY lawn mower is not working yet, I find it's easier to sleep at night
if I just remove the electronic controller from the mower when not used, I'v
seen the same thing used in car sound systems. if someone is strong enough
to carry off the unit, they would never be able to use it. the unit itself
is just a collection of parts that can be replaced. sometimes when I look at the
unit I kinda wish it would walk away some night, because I know I could do better
next time(first try a making DIY lawn mower).
Now if the electronic controller and software was lost, I'd cry buckets of tears.
Sorry only pictures of unit I have are doing other tasks, up here mowing is done
for the year.
PS: My test mowing deck is an Earthwise 24Vdc
I would like to use rotary cutters, not the spinning type like the Earthwise I using.
Tommy
Two-StrokeAbout the software, do you write it on a PC? Does the bot have a PC controlling it?
That would be the smart thing to do...but with it still changing daily, I do slack off on the backups.can't you just back up the software so if it's lost you have a duplicate?
Two-Stroke
Yes it has a on-board PC (Net book) the software is written in C#, it's Wifi connected to PC in the house, for manual
control a Bluetooth palm sized keyboard is used.
Tommy
Yes, the Mule's PC is running XP Home, the base PC in the house is running Vista.Does the netbook on the bot run Windows?
All the input devices are currently off the shelf USB items(Cameras,Compass 3-Axis, Gyroscope 3-Axis, Accelerometer 3-Axis, Encoders), All the output controls (lights,Motors..ect) are not plug&play but could be.is the controller(s) that connects (via USB, I guess) the netbook to the hardware (motors, etc) an off-the-shelf item?
While the main program running on the Mule and in the house are from scratch, eachDid you write all the code yourself or did you find some modules
Phidgets Inc. - Unique and Easy to Use USB Interfaces
US Digital | Products サ E6 Optical Kit Encoder
[8103]=ROD%20426&tx_assistmepdb_pi1[show_article]=988175121]Products and Applications: Search by Name - HEIDENHAIN
I'm not using the below link, but sometimes wish I was.
RoboteQ AX2550 - 2 x 120 SmartAmps 12V-40V Robot Controller - RobotShop
manufacture supplies drives for a number of different programing platforms for the products
they make.
Tommy
Two-StrokeIs the Mule a hobby or a potential commercial project?
Two-Stroke
I'm making it to hopefully help my mom(75yr old) maintain her independent living.
she is struggling between staying in her own home, or going to an assessed living
facility, the main problem she is looking at is the cost of maintaining an independent
life is lawn care and snow removal with her husband gone(past away four years ago).
She named the Mule George, my lover calls it Georgeta because of all
the time and money I spend on it.
but after working on this project for the last 3 months, now I want one for myself.
so I will be making at least one more (once my brother seen it with the 50" plow installed he also wants one).
Tommy
Two-Strokeyou're learning lots of valuable skills
