I change my own also - two cars, a motorcycle plus all the various small engines. You are right in that there don't seem to be many people signing the log. I wonder how much of the used oil is ending up in the landfill...
I'm mechanically inclined, so it's easy for me. I do all the oil changes for all our vehicles and equipment. I keep a couple of two gallon paint buckets with lids handy. As soon as one is full, I pop the lid on and take it to the county solid waste facility.
...No way the drain plug should be almost stripped at this point. There is NO excuse for the missing bold in the skid plating..
I always change my own. I enjoy doing it, and I like knowing how things are done. My mother took her vehicle to WalMart for oil changes, they charged $35 for 6Qts of Pennzoil and a NON-OEM(even though they stock Motorcraft) filter. I started doing the changes in June of this year, to find a missing bolt in the skid plating, and a near stripped drain plug. This vehicle is a 2008, and there's no way the drain plug should be almost stripped at this point. There is NO excuse for the missing bold in the skid plating. I get 6qts of Mobil 1 5w20 and a Motorcraft filter for $34.xx . Savings, Peace of Mind and a quality job for sure. I am a seasonal small engine mechanic, and I charge $65 for a spring tune-up for lawn tractors. On my mowing tractors, the cost for an oil change (one filter and one without) is $12.00 and $19.00, using Mobil 1 in both. I change the oil in everything I own, Push Mowers, Hinomoto (compact tractor), Other Tractors, etc.
