Dixon ztr ram 44 need a replacement carburetor
SparkleNinja
We have a Dixon ztr ram 44 with a Briggs & Stratton 18.5 els500. The serial number is DM-30-76978. I am not sure if the year but think it’s a 2005.
I need to replace the carburetor but can’t figure out which one to order. Can anyone give me more info. Then you
Bertrrr
Look it up on Amazon , take a picture of yours and compare , amazon will show the carb in 360 degree view , I've gotten a few like this and they're almost always correct -
Usually it will list all the engines it is Compatible with
On the rocker cover will be the B & S engine numbers
Using them you can go to the B & S Site and download your parts book ( for free )
That will give you the B & S part number for your carburettor
The carburettor itself should have a number, usually stamped on the top of the mounting flange and tha brand & type number cast into the side near the pilot jet adjusting screw ( where fitted )
