WELCOME to LMF...
Disconnect the kill wire AT the engine... If you then have spark, the problem is in the key switch OR the safety interlock switches... :smile:KennyV
WELCOME to LMF...
Check the seat & brake & blade safety . If one of those failed there is no spark . Your joy sticks have a push button safety on each handle . Seat and brake are contact switches.
If that's not it then look at the wire harness for mice damage make your way to the coil for the spark plug .
