Dixon 3362
outlaw2000
I'm looking for any Dixon ZTR 3362 mower owners. Built in the mid 90's. I need to see if I can have some pictures sent to me of the chassis, preferably the electric clutch area. I need to find where my serpentine idler spring is suppose to be installed. According to the parts diagram it belongs close or near the serpentine belt pulley...just not sure where. I've been scouring the internet looking for any service manuals or maintenance manuals but have not found anything . Any help is greatly appreciated. Thanks in advanced.
You have most likely looked at a parts breakdown like this...
OEM Parts
A friend of mine has one, I should be seeing her this wk, I will try to get you some pictures... :smile:KennyV
KennyV,
I appreciate your help. I've attached a PDF with a note on the chassis tab indicating the part I'm referring to. Also, attached is a picture of the item. Thank you in advanced.
Outlaw2000
  • DIXI1995.pdf
    DIXI1995.pdf
KennyV,
Here's also a picture of the electric clutch assembly. It appears one side of the spring attaches to part number 1938. It's the other end I'm not sure where it's suppose to go. Thanks again.
Outlaw2000
