Dixie chopper battery won't stay charged
hlw49
Yes jumping the seat switch on the D/C will kill your battery. It will keep the relay activated that activates the fuel shut off solenoid thus running your battery down it time. Usually takes 72 hours or so.
macec3(TX)
I reconnected the safety switch. So far no problems. Ruined a rear tire, so the mower is not being used at this time. New tires should be here today. I believe everything is OK since reconnecting the safety switch. I did use the mower for several days with no problems. Thanks for all the replies.
