TaskForceLawnCare
- Dec 13, 2011
- 3
- 386
Those are not a mulching blade or high lift blade. I'm kinda confused at why you want to mulch so bad with your ZTR. I run an an X blade on my inner spindle all 4 blades are high lift blades. I only run gator blades on my mowers in early spring and fall when the leaves are starting to cover the lawns. I never bag leaves but i close my ICD and mulch leaves. They are almost a powder and become compost. I run dixie choppers so I'm not familiar with your brand. I'm also kinda confused at why your cutting thick grass at 2"s try raising your cutting height to 4" and i think you'll get better results. Also I'm positive a fabricated deck with baffles will cut better then a pressed deck but it'll also cost you more for the initial purchase.
