- Nov 29, 2014
- Threads
- 64
- 24,705
Just a couple of points
1) Wd 40 is not a lubricant so don't go spraying it all around your linkages
It is a solvent & Water Displacer which is where the WD bit comes from
Get a can of spray grease to spray on linkages or any one the Innox. or Lannox sprays .
2) the gears inside these boxes have very sharp ( offerings to the blood God ) edges so open with caution.
Jst about every one I have pulled apart the bushes on the shafts were cactus , worn quite oval & the grease was as hard as pitch
