Hello, I was wondering if anyone could help me here.
Basically, I recently purchased a Yanmar YM14 tractor mower which I knew had an issue. The engine wouldn't run properly due to a leaking injector which I thought would be a case of removing the old washer and installing a new one, however when I removed the injector I found the copper washer had been drilled into and is very stuck in place. This must have been an attempt to remove the washer.
I have attached a few photos. Does anyone know how I can go about removing this copper washer?
I look forward to a reply.
Kind Regards
Kind Regards
