Died While Mowing (936404)
Seeing that the right fender contains most of the electrical connections, I would start my search by removing the panel and looking for a frayed wire caused by the stick. Blowing the fuse tells me you need to be looking for a wire which is rubbed bare or bad connection shorting directly to ground. Added point; when doing electrical troubleshooting patience is your friend and NEVER ASSUME ANYTHING, it will only drive you crazy.
