Lawnmower collector
Working on a DGT6000 with a CV740s Kohler 27Hp V twin. It was blowing black smoke and running rich, had a dirty air filter and an aftermarket carb that had been put on a few years back. I replaced the air filter and put another aftermarket carb on. It seemed to run fine until after 30 minuets or so of mowing when hitting a heavy spot and the governor kicks in it blows black smoke. Then would blow black smoke and stumble when the deck was engaged, revs up fine with the deck off. Plugs are carboned up black indicating a rich condition. I'm putting the blame on the carburetor yet, or is there something else I should be looking at? I don't have the original carb as this is a second hand machine.
