matthdouglas
Hi all
I have had my mower for over 20 years now, and on the third drive belt.
I have put in a genuine JD belt about 20 hours ago, and in the last 10 hours, the drive feels like it is slipping.
I am not sure it is the belt, but it is slow and has issues with hills or tough forward progress. The engine etc is fine. It is like a clutch slipping.
I have adjusted the belt tension as much as possible using the instructions in the manual, as attached, and had it all apart again to try and see what the issue may be. All components appear fine and working, except idler 'D' in the graphic, which is quite worn.
My question is,
Is there anything else which may be of issue? (the hydro - which I am informed is maintenance free).
Would the replacement of the idler 'D' really make a difference? A worn idler must make mere millimeters difference, however perhaps that is enough?
Maybe someone has had a similar issue.
Cheers
Matt
My question is,
Cheers
Matt
