- Nov 29, 2014
- 65
- 24,995
So now that your problem is clear, we can get some where.
I have not seen any L 100's in my shop with a stripped input shaft pulley but I will keep that in mind.
What I tend to see more of is the clutching pulleys coming loose so you do not get full tension on the belt thus the belt slips and the mower goes slow.
So now you will have to drop the deck off and get under the mower.
For these jobs I now drain the fuel tank & remove the battery ( if it is not a sealed type ), then sling the mower up from the front axel and stand it on its rear end.
This will not hurt the mower or engine & makes things a lot easier to work on.
The transmission belt runs very close to the mower and is a bit hard to see almost hidden by the side rails.
The other common slow moving problem is a brake full of crud that does not fully release, also very common particularly if you do a lot of rough mowing ( every long grass, weeds ) or mulching ( stirrs up a lot of dust ).
The rarest problem is low oil but this should be very obvious as you will see a build up of dust & clippings stuck to the oil where it is leaking out of the tranny.
Only 4 places, top pulley ( input shaft ) l & r axels and the control arm, all of which have oil sels on them.
