Mower deck Deck Stops after 20 min of mowing
TimBradshaw
While mowing, the deck will just stop after mowing 20 to 30 min into mowing. The engine never stops just the deck
WELCOME to LMF...
I take it it is an Exmark... what one???
:smile:KennyV
Most likely it's the clutch, the wiring or the PTO switch.
I would change the switch first, as it is an inexpensive part.
The clutch normally sells for around $260 and the switch about $15.
Good Luck...
Test the switch,then ,if test ok,hok it back up and test at the clutch,test ok there ,its going to be the clutch
