Thank you, thank you, thank you! Your explanation fits exactly with what I'm seeing and backs up my thoughts perfectly! Now all I have to do is get a #22 spring and find a place to hook it. YOU ROCK! :thumbsup:
Having just put my 38 in deck back together - replacing both spindle assemblies and pulleys, and finding how to put spring #23 back together, (see another post with pictures) We installed the deck and found virtually the same problem which started this thread. i.e. The brake pad did NOT engage the left pulley to stop the blade from spinning when the mower deck was disengaged. - - - See parts manual model series 700, page 26-27. The spring # 22
was installed, having never having been taken off, so one end is attached to plate #2, through a small hole right near the left brake pad which is on #2, and then the other end of this spring is attached to the top hole of plate #4. My spring was so attached as I described above. However - - - the spring was NOT pulling the brake pad all the way back to engage the left spindle pulley. We found that it appeared that plate #2 was binding somewhat. We lubed with WD40 and it helped, but still the spring was not pulling the brake pad all the way in. We then stretched the spring #22 to engage to the 2nd inside top hole on plate #4 which helped, but did not completely cure the problem of the Left brake pad engaging with the Left spindle pulley. We exercised the engage lever a number of times and it started to set the brake shoe into the left spindle pulley. As it is working that way now, I expect that I will have to replace spring #22 which seems to have become weak, as well as in the near future also pull and lube the Pivot bolt #10 on which the plate #2 rotates. ---- Now that I have everyone thoroughly confused, ...These two pictures of the brake spring #22 was copied from an youtube video .
