Hayterman
- Jun 20, 2020
- 13
Hi all,
I'm new around here. I purchased a used Hayter power trim which has a Tecumseh lev115 engine fitted. It started but ran terribly. Missing back firing etc. I removed carb and found float was full of fuel. cleaned carb. Still no good now wouldn't start at all. Removed flywheel and coil. Checked flywheel key OK.
Bought replacement carb still no good. Spark seemed weak to me so bought new coil but still no good actually seems worse than the old one. Pulling hair out so unless anyone has some real knowledge on how to fix it I'm thinking will a Honda GCV engine fit?
