De-thatching
bakerg
I have a section of rotary hoes that we used to use on the farm. The spikes work prety good as long as you don't go to fast, if you do it tears the yard up pretty good.:biggrin:
KennyV
Rotary hoes will work very well if you pull them backwards they will not dig things up as bad...
Pulled backwards they work more like a spike aerator...
I'm going to be putting a set together this summer, just for large areas.... :smile:KennyV
