Howdy Doody
The reviews on the cub cadet deck is mostly with the timed deck. But every brand has the bad reviews with it.
I have found the cub deck to be strong. I have had to replace the spindles. But I take the blame for that as I hit things like bricks and a axe head.
Mine has the 19hp kohler single cyl.
It is a good engine plenty of power and no problems.
So I am assuming the newer model Cubs do not have the timed deck? I read a few specs online and noticed a few things too:
1 - John Deere D125 has a 12 gauge frame so better than some, not as good as others.
2 - The Cub has a 11 gauge and the front bumper and the rear hitch being 9 gauge. I think this is as good as the JD X series.
I really want to like the Cub, seems to be better on paper at least than the John Deere. Thicker frame, KW engine, bigger fuel tank, longer warranty... I also do not mind the front gas tank, I think if they are not going to give you a proper fuel gauge that this is as good as it gets with the sigh glass where you can actually see it when you are sitting on the mower. I also like the "woven" seat versus the plastic covered, plastic gets hot in the summer! Both however have the plastic hood which I am not crazy about either. I mow relatively slow ( try to make it last as much as possible!) and do not have bumps on my property so I do not see this things breaking unless I hit something.
