aussietrev
- Dec 1, 2023
- 8
It is barely running, will start eventually but rough as. If it did break a conrod, depending where it broke, e.g., close to the big end bearing, it would be possible to still run if the piston was up at TDC I guess. I guess there wouldn't be that much of a problem of power down size for a new 18HP against a tired 20HP. Plenty of 42 inch cuts run similar engine sizes.
