Hello,
Since a few weaks i am busy to revise a old lawn mower (1993).
A few weaks ago i cleaned the engine (cyllinder, carburettor, bougie, flywheel, air inlet, oil) and started it, this ran fine at that time.
Now a few days ago i saw oil leaking from the gasket at the cyllinder.
I openend the cyllinder today and i discovered half the cyllinder was filled with oil.
I also noticed a screeching sound from somewhere around the crankshaft, this was not there when i started it.
I have not done anything weird with the engine it just laid on the ground.
The engine is a 4 stroke one cyllinder 12.5 hp briggs and statton and the model number is: 288707.
Does someone know how to fix this?
Berend
Berend
