Sockmonkey
Check the governor linkage/settings.
I agree!Worn valve lifters will give that symptom. They are Hydraulic Lifters, and they wear out.
We had a similar issue on a CH740 in a Walker. Replacing all four Hydraulic Lifters resolved it straight up.
One thing that caught my attention in your other post was that you said when it's running with no load it's about $3,600 RPMs which I feel is a little bit high but not terrible. Most of these mowers are designed to run no more than 3,400 today but again, I forget what it's actually on and I think it was a larger gravely but don't remember if it was commercial residential but regardless 3600 is not terribly fast.Can anyone help here?
I'm absolutely baffled by this issue. I am now 100% out of ideas. The problem presents itself in two ways.
1. Within the first few moments of average load mowing, the motor RPMs dip significantly (about 5-10 seconds after engaging everything ). The greater the load, the more the RPMs dip. I hooked up at tachometer and it shows 1200 at low idle, 3600 "high idle", and during mowing it will usually sit right around 1700 RPMs depending on load (barely enough to mow). If it's a downhill, it'll go to 2500 or so, and small uphills dip to the point of basically being at low idle speed. If at any point I pull back the sticks to a stop (blades engaged), rpms will slowly pull back up to 3300+ RPMs (in 3-5 seconds). Push the stick forward and it dips back into the 1700 range.
2. Using clean plugs, cylinder #1 plug is always turns sooty black (carbon fouled) after a ten minute mow. Cylinder #2 is white to very light brown (varies). But never rich like #1.
I've put together a spreadsheet to track this problem. Just because after checking EVERYTHING I wanted to make sure I didn't miss anything. I know it's a lot, but it will show that I've tested all the typical problems.
The mower is a 2005 Gravely 260z (zero turn) that I bought a month ago for cheap.
I'm completely at my end here and would be happy for any experienced ideas.
