Turbodriven
- Aug 18, 2023
- 84
I currently have the belt off so I could take a video of the spindles spinning by hand. They don't sound gritty to me like bad bearings would. I'll check again though with some side tension applied. And I'll take a pic of the blades but I did sharpen them. No idea what they are though.What I hear with headphones on, from your video OP, is normal RPM's in the first video. Low idle is lower than you will ever use and high sounded fine to me.
Your next video, sounded like, you have one or several bad bearings in the deck. Sounded awful mechanical when you engaged the blades. Heard a lack of engine rpm with the blades on. Like you have some aftermarket blades or some high lift wonder blades of the week on her. Are you running OEM blades?
Summation the engine sounded fine until you loaded her up. I would be looking into the deck then the engine if it was me. Or your Chinese tachometer is not reading proper rpm's. All this valve and such talk is getting you no place fast.
It's also important to note that I'm getting a slight power loss even without blades engaged. I'm at about 2500 rpms on flat ground just driving around. I haven't focused on blades/spindles because of this.
