The Push mower
- Aug 22, 2020
- 13
- 51
Wondering if the pros could give opinions on these journals and surfaces. Mower was hammering like a rod knocking while running and cutting fine. Turned out to be a cam in two pieces. Can't believe it actually ran and cut. This second cam (used) lasted about 5 seasons. First cam was replaced due to compression relief failure.
