cruzenmike
- Feb 10, 2017
- 59
- 858
Hello All.
Went to use the John Deere today and after about 30 minutes of using it, the engine started making a loud ticking noise. The noise only happens once the engine is up to temperature. This has happened 3 times already but it is only after about a half an hour of mowing. If I shut the engine down for 10 minutes or so and then start back up, the noise is gone. Since the engine isn't completely cooled, it gets back up to temperature rather quick and the noise comes right back. Not only can I hear the ticking sound coming from the front of the engine, I can also hear that the engine sounds different (exhaust noise changes). I am not having any issues with the engine missing, sputtering, surging, stalling or backfiring, it's just making the ticking noise.
I looked around on the web and all things are pointing to a lifter issue. I am using Kohler synthetic 10w30 oil which was just changed about 3 (engine) hours ago. The engine has had a complete tune-up this summer and is not having any other issues.
What could be causing this problem and is it easily fixable?
Thanks guys!
Mike
Thanks guys!
Mike
