Hammermechanicman
- Jan 10, 2020
- Threads
- 65
- 3,830
You are obviously trying to sell a new belt to simply enrich yourself, when it is painfully obvious THAT belt has at least 10 more good years.Hmmmm. Belt maybe?
I guess i need a can of that fer shur.just spray some of this on it View attachment 57048
or twoI guess i need a can of that fer shur.
I bought a rigid frame zero turn from a guy who gave up on it. He had hundreds of pounds of weights on it and never reached the conclusion that, if you want to turn right, pulling back on the right side does the same thing as pushing forward on the left. One of the drive tires will always be in contact with the ground Unless you're in really close quarters and can't do this OR if the drive tire in contact with the ground spins. My ground is pretty rough but I haven't been stuck yet.Troy Bilt mustang ZTR50. One of the lightweight homeowner grade Z. Customer trying to get more weight on the drive wheels.
