You can check the switch with a volt ohm meter... there is very little wiring so wring out should be very quick and easy... :smile:KennyV
Well I replaced the ignition switch and it started right up. It ran good but then died. It did this a couple of times but would always start again if I wiggled the positive battery cable. (The cable is not loose)
I blew snow for a couple of hours yesterday and just went out and started all over again after our second blizzard in as many days. I got all the way to the end of my road and BLAH. It died again. Turned the key and nothing again. Wiggled the cable. Still nothing. I had to pull it all the way back to the garage.
I'm just confused as to what could be causing this.
