When you say "pull", do you mean you unplugged the connector? Or that you physically removed the entire switch and connector? The connector may have a shorting bar to prevent users from disconnecting the seat switch, so that the mower will always die with the parking brake off.I have a Cub Cadet XT1. When I let off the brake the engine dies. When I engage the blades, the engine dies. I have pulled the seat safety switch and it does not seem to matter if the switch is in or out, it still runs. Can not make sense of it.
Help Please.
T
Are multiple problems Cacti? I like that I have never heard that phrase up my way Thanks!1It sounds like the switch is cactus
If it is a 2 terminal plug then try jumping the terminals
If it runs fine with the bridged but not with then open the the switch needs replacing
If it makes no difference then the wiring is cactus
Note this is for the purpose of diagnosing the mower .
I just had that problem. It worked fine when I put it away yesterday. Today was as you described. I had acorns between the seat and the seat switch. I had to disconnect the switch to get them all.I have a Cub Cadet XT1. When I let off the brake the engine dies. When I engage the blades, the engine dies. I have pulled the seat safety switch and it does not seem to matter if the switch is in or out, it still runs. Can not make sense of it.
Help Please.
T
