soundtechmike
- Jun 5, 2014
- 2
- 3
I know i need model but when i thought to post this i cant remember the model. it has a 54" deck. its a conventional tractor not a zero turn. problem is that it works fine for about a half hour then it will start slowing down more and more till it finally won't move anymore. Let it sit for 20 minutes then it goes again fine for abot 20 minutes then starts slowing down again. i bought a used transmission from a repair guy around here and put it in with new 20-50 oil thought that would fix it ... It does the exact same thing. And yes has new drive belt and i checked to make sure the brake was not hanging up. is this a common problem with these hydro gear transaxles. Any feedback would be greatly appreciated.!
