double yellow
- Apr 19, 2023
- 6
- 70
Thanks for the reply, but it is a single cylWhen you start it back up, does it run fine for another 20 minutes? Could a coil be going bad and it goes down to one cylinder after it heats up after 20 minutes?
Model # 13VAV1CS009 11102373 Serl# 1C237H40229 XT1 LT 42KH Check carb ,gal line and filter all check out fine. Tried to cut grass today. need fine for about 25 min. then started bucking and trying to cut off. It is worse when blades are turningPost up the model, type and code info of the engine.
Using that model number from the tractor leaves room for lots of speculation and Cub used several different engines on the same model tractor at times so with engine info we can then maybe get on the same page as you.
thanks
Will checkStart with easy mechanical thingslike valve lash
Excessivly loose exhaust will do this.
If they are OK check the coils by removing the kill wires for a single mow ( don't forget to replace them )
Then there is a vacuum lock because the tank vent is not working so loosen the fuel cap so air can get in
Work your way through that lot & get back to us with the results .
TStart with easy mechanical thingslike valve lash
Single cyl. twin cam 18hp Model # 13AVA1CS009-11100273 Out of warrnty154 hours on the machine.
Is it still under warranty?
Is this link the machine?
could not find a 13VAV1CS009 ENGINE
PartsTree - Home of OEM Parts for Outdoor Power Equipment
Parts lookup and repair parts diagrams for outdoor equipment like Toro mowers, Cub Cadet tractors, Husqvarna chainsaws, Echo trimmers, Briggs engines, etc.www.partstree.com
Is it a Kohler single cylinder?
