jeepguy181
- Oct 15, 2015
- 1
- 1
Hey guys, first cub cadet. model 2206 I recieved for free. Needs quite a bit of work if I was going to fix it up to look nice as well as running nice. But only interested in running nice for now.
As far as history that I know is that it sat for x amount of years. Air filter looks clean. Naturally it's going to get oil change, trans tune up, and spark plug. My question is I'm very limited on small engine repair let alone any size. I read it's not very easy to drain the trans. I did find the trans filter, where is the drain plug on it? Or is it reccommended to just take the simple way out and suck the fluid out, change filter and refill the trans? How many plugs are in them? Where are they located and how many are there? (only other strongest mower I owned is a 12 horse power. No where near 20 horse power.) What's the easiest way to change the oil? pull the side panel on the left side next to the hood? I saw the filter there. How is the Kowler engine? Always thought the briggs and straton was the best out there.
I'm working on a very limited budget esspecially with winter only couple months away and only having seasonal work. Any help would be appreciated.
