tprice1167
- Jul 27, 2019
- 1
- 3
My Cub Cadet LGT 1054 was not charging the battery so I replaced the rectifier. It still wasn't charging the battery so I was just putting it on the charger and mowing - then it suddenly stopped and wouldn't turn over. I knew the battery was good so I traced it to the 20A fuse. As soon as I replace the fuse and put the battery back in - it blows. Does that mean there is a direct short somewhere? I followed the red/white line from the fuse to the key switch and don't see an obvious break in the wire. Not sure what to check next. There is a relay also on the wire harness - could that be what is shorting out?
Thanks for any help in advance.
TP
TP
