I have a zero-turn CC Z-Force SZ48 with Kawasaki FR730V engine... Started having problems a couple weeks ago when it would stutter/sputter then die after running for ~20-30 mins. If I waited a while, 15-20 mins, it would start up again and then run for a while again, then die again. Talked to someone at the dealership who thought it could be the ignition coils. So I replaced the coils... But it still does the same thing.
Friend said it needs to have the jets cleaned. So I have the air filter off and am looking inside the bowl but can't really see the jets the way the carb is designed. Have sprayed carb cleaner into it and run it just idling. Not sure this solves the problem.
I've looked for vids of disassembling the carb but cannot find any! Any links on how to disassemble and get to the jets? I'm new to the small engine kind of thing... Any help is appreciated.
