cub cadet is running very slow but Engine is good
  • / cub cadet is running very slow but Engine is good
Don’t be hard on a new guy trying to help, not everyone is used to how the threads are dated.
logert gogert
Don't listen to these posts, beacuse they have no idea, and probably have over 10,000 posts a month. Okay what you need to do is remove the engine drive pulley that connect to a shaft attached to the brake lever. This pulleu (s) keep tension on the drive belt. This plate is attached to the frame via, a bolts that has a brass bushin in it. It is rusted tight, so the full tension is not applied when the brake lever is release, Clean it, put the should bolt in acid for a few minutes, lube it and back together.
its okay, we all know your trying to help, and by the looks of it you have a good amount of knowledge to help the pros on here, but if the thread hasn't been active in over a couple months, don't bother replying to it, and if you don't know how to tell where/ how old the thread is, its okay ill tell you
if you look at the top of any bodys post ( on the thread ) if you look just about an 1/4 of an inch on top of their "statement" and you will see something like this (just an example): "Yesterday at 10:46 AM"
and that date and time will be in a light grey.
if the most recent date and time is over about an month old, don't worry about replying to it
and theres also a way to see when the thread started ( date )
if yo scroll all the way to the top you will see the title of the thread in bold black letters
and for this thread it says, "cub cadet engine is running very slow but engine is good."
then once again about an 1/4 an inch under that you will see a forum username in light grey, and that name will be the person that started the thread.
and right next to that ( in light grey words ) you will see a little clock symbol with a date next to it, and that date of course is the date that this thread was started.
so for this thread it says
nigelbb Aug 14, 2011
and thats how yo figure out dates and times ?
now remember, when your viewing a thread that you're about to reply to, remember what i have said before you reply.
-logan
Sorry I came off a little rough but he has been a member since 2014 so I would think he would know by how the system works.
logert gogert
noooooooooooo, you didn't come on rough, i actually laughed so hard!
it was so funny because i read the post you said in a "dude WTF were you thinking voice" in my head
do u know what i mean?
And the OP never actually cam back with the mower number so it could be an original International Cub , a stand alone Cub or an MTD Cub .
For the heck of it I did try to reverse search the part numbers for the shim washers to see what they were ised on but came up empty .
They used on the following machines though these parts are now NLA.
2130 Tractor S/N 239,001 - 326,005 134-212F100 135-212F100
2130 Tractor S/N 326,006 & Up 136-212F100 13A-212F100 13B-212F100
2140 Tractor S/N 239,001 - 326,005 134-232G100 135-232G100
2150 Tractor S/N 326,006 & Up 136-242G100 13A-242G100 13B-242G100
2160 Tractor S/N 239,001 - 326,005 134-266-100 135-266-100
2160 Tractor S/N 326,006 - 389,000 136-266-100 13A-266-100
6284 Tractor 54AD64H-710 54AT64H-710 54BD64H-710 54BT64H-710
7264 Tractor 54AB746-100 54AD746-100 54AT746-100 54BT746-100
