Cub Cadet i1046 PTO clutch removal
wtp3
I can't get the clutch off to change the belt.
Does anyone have some clues?
Does the clutch even need to be removed to get the new belt on??
Im not familiar with the model but usually you can get a belt on/off by just releasing the tension on the idler pulley or removing the deck.
You may need to use a 3 claw gear puller and spray that sucker good with PB Blaster for a while..I can get any pulley off with a good puller and impact gun.
Tom
