christophert
A customer brought a Cub Cadet Enforcer into our shop with a major electrical issue. The original Kohler engine had blown up, so he installed a larger Kohler 24HP Model (KT-735-3104) replacement engine which was not interchangeable with the factory harness. Well, he cut and spliced the original wiring harness so it would run, but it had a short in it causing it not to charge and burning up batteries as well. He brought it in and I ordered a replacement harness from Cub Cadet and pulled out the old harness and installed the new. I discovered while doing this that several grounds had been cut off and deleted, the drive belt was sawing the main ground wire in two (since replaced and rerouted), and the rectifier was bad. I have replaced the bad components and when I went to start it, the starter engages the flywheel and will not disengage. The wiring is hooked up exactly as before (the plug-ins.) I did replace the ignition switch with a factory Cud Cadet one for this unit. Where do I need to look next? This unit has been Pandora's Box because of the customer's engine swap and subsequent rewire (with a short) that required the new harness. I appreciate any help.
