Pretendfarmer
- Aug 12, 2019
- 1
- 5
Good morning all,
I recently picked up a 2004 Cub Cadet 7264 compact tractor. It has a bucket loader on the front and a backhoe on the back. Its in good shape, runs good and the hydraulics for the implements work fine.
The only issue is the hydrostatic is very lazy. Most of the pedal doesnt do much. When I depress it all the way forward the tractor moves but its slow. It will not back up a hill either. When it does move, the hydrostatic is quite noisy. I've driven many hydrostatic tractors and this is not normal. It will free wheel down hill which I know its not supposed to do. I did put the bucket into some dirt, and it would force the bucket into the ground in the forward direction but the hydrostatic was quite loud. It seems like the hydrostatic drive is staving for fluid.
The hydraulic fluid was recently changed out and new filters are on it. Short of the pump being worn out, it has occured to me that these could be the wrong filters, too restrictive. They are NAPA filters, not the cub cadet ones. I also wonder if the wrong fluid is in here, if that could cause this. Any opinion on that is appreciated.
So in short, could the wrong filters cause something like this? Will any hydraulic fluid approved for use in a hydrostatic tractor work for this one? Thanks
